wacorider
- Feb 10, 2009
- 0
- Ford
Hello all you Ranger fans...thanks for the help on the electric window...the repair was very easy, once you know the secrets
Long standing problem...93 Ranger, stock, 4 liter, 4x4, 292.000 miles...been having a problem with the motor detonating, sometimes called pinging, at rpms above 3000 on acceleration...not a fuel problem, all sensors gathering data have been replaced within last 10 months, including rebuilt injectors ...problem seems much worse during the hot months...runs well cold, as in the winter time (I'm in Indianapolis)
Have not touched/replaced the Ignition Control Module (Sometimes called the EI Module in the Ford Dealer Service books) or the Powertrain Control Module.
Each of the last two mentioned items are about $140 each to replace, but I would rather understand the problem, than just throw money at it.
I do not have a diagnostic device, so I cannot check codes.
PS can anyone recommend a diagnostic device , ie what, where to buy, etc?
Thank you!!
Doug B
Thank you!!
Doug B
