differential identification help
non rotary mazda
Mazda
I have a 2008 Mazda B2300 with a 5 speed manual and would like to get the right lube for a differential service. I have done some web searches and am not finding what I need. The ID tag on the diff cover reads as follows:
V326A
73 75 7M17
I am trying to find out if I have a "Traction-Lok" diff as the book calls for different oil if it does. Thanks in advance for any help given in getting this figured out.
8,372
Welcome to TRS :)
Easier to look on the drivers door label, go here: http://www.therangerstation.com/how-to/axles/ford-7-5-8-8-inch-axle-tag-door-codes/
On the back edge of driver's door
Find AXLE code
If its a Letter and number then its Trac-lok(L/S) if two numbers then it is OPEN
But you can use oil with friction modifier in either, you just MUST use it in trac-lok models
L/S = Limited Slip, the common generic term used for Ford's Trac-lok, or GM's Posi-traction
tinman_72
137
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Are you sure the fourth digit on the bottom is a 5 and not a 3. That is where Ford puts the gear ratio. I have never heard of a 3.75 in a Ranger but 3.73 is pretty common. If it were limited slip there would be an "L" between the first 3 and 7.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Just run mobil one synthetic and you're covered either way. :icon_thumby:
Actually it looks to me like he is missing the first 3. Also, Ford won't use 3.75 gears. They never use gear ratios where the second number divides evenly by the first number. Doing so makes the same teeth have regular contact and sets up wear patterns that cause gear whine much earlier in the gear's life.
It looks to me like this is an open 7.5 rear.
Mac
183
C. Wisconsin
2000
199
Number in front of 73 gets covered by bolt half the time so it would be the 3.73 gear, 7.5 open axle.
Dave
8,372
Dave
Yes, ^^^ missed that one
