Directed 556U to bypass chipped key?
backporch
9
NJ
Ranger Off Road
245 75R16
I have a 99 Ranger XLT and I believe I can put my only chipped key in this bypass and use non-chipped keys. Anyone have any experience with this kind of install?
8,374
These types of immobilizer interfaces are to use for remote start setups, you don't need this if you just want to use "regular keys"
These shouldn't let anyone use a regular key to start engine, that would means PATS was disabled and thats not what these are made for.
For remote start system when you open the door or touch the brake pedal the remote started engine should shutdown, and won't restart without working PATS key in the ignition.
This prevents a thief from driving off your vehicle as it warms up
To do what you want, get a Regular key cut/made, then remove the steering column cowl , 2 or 3 screws
You will see the Transceiver ring around the key slot, looks like this: https://i.ebayimg.com/images/g/NZkAAOSwjVVVppqL/s-l300.jpg
This is what "reads" your PATS keys number when you turn on the key
Tape your PATS key next to the ring
Try to start engine with "regular key"
If THEFT light flashes rapidly it can't read the PATS key, try a different location for the key
Once it can read the PATS key each time regular key is turned on secure PATS key at that location and put cowling back on
Worst case is you have to remove the transceiver ring and move it down under the dash and tape the PATS key inside it so it can be read everytime
Alternative is to have your working PATS key Cloned, locksmith can cut key and Clone/Copy the same number on to a New PATS key, so you have a working spare key, at a lower cost than having new PATS keys added to PATS memory
Just FYI, this is what the 3rd party Remote start setups do, they "read" the key number during installation and setup, then they use that number during Remote start, so an electronic Clone of your current PATS key
backporch
9
NJ
Ranger Off Road
245 75R16
Just got around to making the Ranger ignition no longer require a chipped key. There wasn't enough space to put the key below the cowl and I didn't want to destroy the key. I used the solution suggested to remove the transceiver ring. It was relatively easy.
Put any key for the truck into the ignition, turn to run position
Use an awl and insert into the hole under the ignition to free the ignition lock cylinder assembly
Pull ignition lock cylinder assembly straight out
Remove the single torx screw holding on the transceiver ring
I zip tied the chipped key to the ring with chip beyond the ring, like it would normally be positioned
Test that the truck starts and runs with a non chipped key
Put the ring and chipped key in the dash under the steering column.
Works great. Thanks RonD for the advice.
fastpakr
2,849
Roanoke, VA
For some reason I thought the Directed module was designed to be paired to the PATS module as if it was another key rather than requiring a bypass.
8,374
The 3rd party remote start modules need to "read" a working PATS key number during setup, they store that number in memory and then send it out to PATS module or PCM when remote start is activated.
So same as starting engine with that working PATS key in the ignition, so its not a "bypass" its same as getting a "cloned" PATS key
Ford Remote start units use an "electronic" PATS key, it has a new number and it must be added to the PATS Module or PCM just like a new PATS key would be added
fastpakr
2,849
Roanoke, VA
I had to go back and check the instructions for mine (haven't installed it yet), but it appears to be identical to the factory Ford remote starts in that respect. It's a Directed 555P, and here's the relevant section of the instructions:
The module has a fixed key code. This is hard-coded into memory. Programming consists of learning the module into the vehicle. Note that two vehicle keys are required for this procedure.
Learn Routine
1. Using 1st key, turn ignition to the ON position for 2 seconds (the “Theft” light will turn off). Remove the ignition key.
2. Repeat step 1 using the 2nd key.
3. Start the vehicle with the remote starter. The “Theft” light should turn ON then OFF after a few seconds.
Programming is now complete.
8,374
Yes, that would be an "electronic key" like Ford system uses, requires two "working" PATS keys to add a 3rd, or 4th
Other 3rd party units just require you to turn on ignition with working key, and it reads that keys number and stores it to memory to use for remote start
fastpakr
2,849
Roanoke, VA
