trailbikerider
- Jun 18, 2010
- 0
- Kalamazoo, MI
- Engine Size
- 4.0L
Well I just finished up replacing the slave cylinder in my '94 2.3 2WD, because the truck would not disengage the clutch even with the pedal depressed. After it was installed, we could NOT get the system bled, no matter how hard we tried. So today I picked up a pre-bled Master Cylinder & Line combo at work and slapped that on. I have pedal and I'm about 99% sure the system is bled, as the slave is moving roughly 5/16". The truck STILL will not disengage the clutch, and I can't get it into any gear. What's the deal here? The only other thing I can think of would be the "fingers" on the pressure plate are misaligned, causing it to disengage crooked. Before I pull the transmission for the second time, I want to make sure everything has been looked at, bled, etc.
