Baseline
- Dec 13, 2023
- 0
- Boston
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
I wanted a truck camper for my 2wd 09 ranger.
Few campers are available for small trucks, and those that exist are extremely expensive.
I decided to create my own using full size truck caps.
The full budget of the project was $150.
I drew the design, photoshopped the design, then acquired the used caps.
I merged the two shells and built wooden frame along the base and around the rear opening.
I framed doors into the rear. I built a wooden support frame and put the unit on wheels.
The camper shell rolls around my yard on 8" pneumatic casters.
I can move it on and off my truck alone in 5 minutes.
The camper ties tightly to the bed hooks with turnbuckles.
The rear doors are now enclosed and painted white with a nice locking handle (not pictured)
It will be good to add a nosecone when time allows to improve the aerodynamics.
Initially I estimated it would weigh 400 lbs. I think it is around 500 lbs in reality.
The camper may weigh 500lbs, but it extends 2' out beyond the tailgate and is rear-heavy.
Therefore the leverage on the suspension could effectively be equivalent to an ~800 lb load.
The truck is rated to carry 1168 lbs.
I drove the camper around town for a month as I worked on it, and took one long road trip (7 hours round trip).
On the highway I drove slowly to keep the wind load reasonable.
Prior to this build, I replaced a driveshaft U-Joint last summer (6 months ago).
The second U-Joint blew out during the month I drove with the camper (1 month ago)
I drove slowly around town @30mph with a semi-squeaky joint for two weeks before a mechanic replaced the second U-Joint.
The mechanic also replaced front control arms.
Post-mechanic, I bought new tires, had an alignment, and balanced the tires.
The truck now vibrates at 40, 60, and 80mph.
At 85 mph the vibration is alarming.
The mechanic spent a full day with the truck on multiple test drives.
They concluded the vibrations are from bent rear axles.
Our roads are full of potholes. When the truck drives over a pothole, that momentary impulse magnifies the load greatly.
The rear suspension on the truck is 15 years old. It was degraded and cannot carry full load.
They recommend full rear axle/diff assembly + driveshaft replacement. Est = $2500
They recommend full rear suspension replacement. Est = $1500
Questions :
What suspension upgrade is required to carry this camper on this truck?
What drivetrain upgrade is required to carry this camper on this truck?
Should I throw this thing away and forget about it?
Thank you for reading
– Baseline
Questions :
– Baseline
