Do we have a Brake Controller Plugin?
Bartowski
Starlight, PA
Hi All!
I have a 2003 Ranger Edge with the 4.0 and towing package - does anyone know for sure if it should have the clip/connector under the dash to attach a brake controller? I've seen a few threads on it, with lots of guessing, but no one saying yay or nay. Just figured I'd ask before digging around or buying and adapter. Going to hook up a 7-pin connector as well, but that end should be fairly easy! Thanks for the help!
8,372
There probably isn't a definitive answer, so no confusion over it.
A Blue wire is the universal standard for electric trailer brakes so see if you have a Blue wire in the trailer connector, if you don't then there is no e-brake wire
Good look here at wire colors Ford and others used for trailer hook ups: http://www.therangerstation.com/tech_library/TrailerLights.shtml
alwaysFlOoReD
5,132
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The only definitive answer I have is "I've never seen one". I've put in a few 7-pin connectors in Rangers and have had to run a heavy blue brake wire and a heavy red battery +ve wire from the aftermarket brake controller at the dash.
My wag is the ranger isn't meant for heavy towing so they never put in a 7-pin tow package.
The Ranger I'm driving now shows signs of a fifth wheel hitch and came with the 7-pin already installed [not factory].
To the best of my knowledge no. Ford never had a factory option for a 7-pin trailer connector on a Ranger, and thus did not include a factory hook up for a trailer brake controller.
don4331
1,353
Calgary, AB
5.3
My opinion: 7 pin wiring isn't included in the Ranger Electrical and Vacuum Trouble shooting manual, so I'll put my money on not there.
Ford was too...frugal...to include wiring for Power Window/Mirrors in vehicles which didn't have them, and that is just wire across width of dash. To run wire from cab to rear bumper is considerably longer...
On other hand, given Ranger's rated towing capacity/almost every state & province's legislation requires trailer brakes; they certainly should have included it.
I know vacuum & surge brakes don't require 7 pin connectors, but e-brakes are so much more convenient.
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
I'd say no. Theres a lot of full size trucks that don't even have the plug-n-play harnesses. The ranger is a mid-size truck and not really made to tow anything that requires a 7-way plug or brake controller. I'd say if you are towing something and you want a brake controller then you may be towing out of the leagues of a rangers capabilities. I work at an RV/camper dealership so I see the wrong trucks towing things waaaay to heavy all the time and it becomes a safety hazard. I don't like nagging but if you are trying to tow something that shouldn't be towed behind a "half ton" truck then you put yourself and other drivers around in danger, let alone the strain on the transmission and suspension.
heavy breather
I fully understand your concern, but IMO, having brakes on even a small trailer behind one of these trucks is an improvement. I also want to add a brake controler, and I only really tow a 4wheeler or two.
