Drag link?
vDawG
Truro NS Canada
Bronco 2
Just wondering what size heim joints and tubing to use for my drag link? Please post what has worked for you.
crawlin91
60
Crawlorado
2.9, 4.0
1.5" o.d. X 0.25" wall DOM
3/4" or 7/8" heim with threaded tube adapters to fit 1" i.d. tube
or buy a reamer and use one ton TREs instead
vDawG
Truro NS Canada
Bronco 2
Is one option stronger and more stable than the other?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
If you drive on the road more 50% of the time or more, I would HIGHLY suggest using TREs.
vDawG
Truro NS Canada
Bronco 2
If I understand correctly I order 1 ton tie rod ends from a f 350 or something and ream out the holes in my pitman arm and my steering linage... correct? How do I get the size and taper/ angle reamer right? I know I am showing just how green I am on the subject. The process sounds easy but screwing it up and finding new parts wouldn't be.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
vDawG
Truro NS Canada
Bronco 2
Thanks a million!
koa's93ranger
Las Vegas
4.0L V6
After many many pages of research for my own build, I strongly suggest against the taper inserts. The hole would be so big that your pitman arm and knuckles would be very weak. I was going to go this route but knowledgable gurus have advised me against it and have saved me from having to replace those parts after they break. And the reason you go with Chevy one tons is because they are stronger/slightly bigger shaft and are more readily available.
Just some things to consider. Other than that, crawlin and brinker are right on point
vDawG
Truro NS Canada
Bronco 2
I did some checking around at local performance shops and 1 one of them told me the chev tre's are 18mm and 1.5 pitch. They also said they couldn't get the bungs to fit. Where did you guys get the bungs? And was the local shop correct on the thread? They recommended I get tre's that use standard thread because they bith carried all types and sizes.
