Drain Plug Location on the Transfer Case?
rangerenthiusiast
Hudson Valley, NY
I have a ’92 Ranger Supercab 4x4, 4.0, A4LD. Can’t seem to find the drain plug on the transfer case. Found the fill plug on the back side of the case no problem and was shocked to find that it was actually full (the PO did NOT maintain this truck). Looking to drain it and put in new however, since it looks and smells old.
According to the Haynes manual (which is completely worthless for this vehicle, BTW), the drain plug should be about 4” below the fill and to the left (that is, toward the driver’s side). Instead, there’s a bunch of other crap bolted on there. Do some of these cases have to be suction pumped out or should there be a drain plug somewhere?
Also, on the other side of the transfer case (the front), there is a peculiar looking hose:
https://drive.google.com/file/d/1b-eDu48v57RfN2hHmDGX4C3cCAohObnN/view?usp=sharing
It was dry rotted and practically falling off anyway, so I took it off and this fitting was underneath:
https://drive.google.com/file/d/19Is4Kh0E7wScYRW4gSicjE6KDTkQiV2N/view?usp=sharing
Is this just some kind of breather hose to allow built up gases and pressure to escape the transfer case? That’s the only thing I can figure...
Thanks.
Denisefwd93
74
South East PA
I actually know the answer because I did it on the transfer case when it was out of my truck! It's kind of behind the big round counter weight.
rangerenthiusiast
Hudson Valley, NY
Is that what that thing is?? I had a funny feeling that it might be under there, since that’s exactly where the plug is supposed to be as far as position. So I guess you just unbolt that big round weight and the plug is exposed?
Thanks a bunch, Denise. :icon_thumby:
Denisefwd93
74
South East PA
Oh you're very welcome I actually did this while Hank was laying under the truck wrestling with the transmission. I used Castrol synchromesh fluid
