fordman49450
- Aug 7, 2007
- 0
- Michigan
- Ford
I was thinking of purchasing a 1 piece driveshaft for my 94 ranger but when looking at the picture at the top of the swap in the tech library it appears that the short piece of the one piece driveshaft with the slip yoke is about the same length as the one on the 2 piece to where it is connected to the midship bearing. Does anyone know if this is true? if it is, then exactly how much longer is the main driveshaft? I guess what i am asking is could i just take my 2 piece driveshaft and seperate it from the little shaft at the midship. put the end off that bolts to the transfer case and put it on the little part of the main shaft and just have the main section lengthened? if so, how much exactly does it need to be lengthened to work? I was just thinking of this as an alternative to taking down the skid plate on the gas tank because the diamater is smaller and also to have it lengthened and balanced locally here is 100.00 so compared to the 90 that a junk yard wants it's not much more and may save some work.
