fordman49450
- Aug 7, 2007
- 0
- Michigan
- Ford
ok I have a 94 ext cab ranger 4x4 with 4.0, M5OD Trans with a electronic shift transfer case. I bought a 1 piece driveshaft for a 98 ranger ext cab. The rear flange for the axle bolts right on but the front where it bolts to the transfercase is a bigger bolt pattern then the transfercase flange. I was going to change the end on the driveshaft from the old to the new but the U-joints are different. the old driveshaft has a u-joint that is 3.25" approx from cap to cab on both axis's. without the caps it is approx 3". the new replacement driveshaft ujoint is 3 5/8 from cap to cap or approx 3 5/16 without the caps. the caps on both driveshafts are 1 1/16. SO I guess I need to get a u-joint that is the same on one axis as the old driveshaft and the other axis needs to be the same as the new one so I can put the old driveshaft flange on the new one. If anyone can give me a part number this would be great as none of the parts stores here are of no help at all even with measurements. Thanks.
