Eagle Eye lights?
02RangerXLT
53
NE
Does anybody have the Eagle Eye 130watt (spot beam) off road lights? If so, what do you think of them? I saw them (http://www.rdmoffroad.com/eagle-eye-5-eagle-off-road-light-55w/100w/130w.aspx?variation=1831) and didn't know if they were any good or not? I need something that puts light out at a distance and KC's and all those are just too expensive right now.
Thanks for any input :icon_thumby:
PS: The ones in the link are the 5" ones, but if you have 6" ones that would be fine too.
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
i have the big 6x9 rectangular ones, but one has a broken lens. very powerful.
poor man's off road lights:
get a pair of the 4 3/4 inch rubber housing utility lights.
at NAPA or another decent auto store, order up a pair of the 100 watt aircraft landing lights of the same size (PAR 35 or something).
swap the lights and use heavier wire and a relay.
mount 'em up and your good to go!
about $40 doing it yourself. also, you can change the beam. as the sealed beams have a about a 1 inch coil for the light, you can mount them with the light coil horizontal for a little wider beam, or vertical for a longer, narrower beam. they do really well in the rubber housing as they can take lots of vibration and pounding and not break.
i use them. good luck.
02RangerXLT
53
NE
Yeah, I think I'm going to get those Eagle Eye's. I can get them for $72 shipped, and they appear to be well made, metal at least, rather than the plastic on hella's, which I was looking at previously.
machine090767
Minnesota
5.4 Triton V8
Perfection is worth the wait
Eagle eye lights are cheaper (in price and quality) than KC's or Hella or PIAA, However, with the Last 3 brands mentioned, if breakage occurs, they have warranties (KC) or replacement parts if needed. With the eagle eye lights, if a lens breaks, or something else happens, you have to replace the entire light, or kit (depending on the model)
If your in a cash strapped situation, go with the eagle eyes. If not, get some KC's (since your looking for some long range off road lights)
02RangerXLT
53
NE
I decided to go with some KC's, so hopefully they perform well. They have 55w bulbs, should I consider upgrading bulbs?
