EGR Tomfoolery
Randarial
Livermore, CA
4.0 Liter
So just thinking out loud here, but i heard that a fuel pump block off plate for a 351C will fit perfectly between the EGR valve and the intake manifold basically capping it off. If i do this will she throw a code at me you think?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yes, you will get a cel for insufficient EGR flow.
3,614
And since your truck is OBDII you won't gain a got danged thing but problems. Assuming the system is working right in the first place.
Jsommers
michigan
my egr tube kept leaking at the intake so i plugged it at the intake and cut the tube off. hasnt gave me problems yet besides the insufficiant egr flow code
Jsommers
michigan
btw i didnt gain anything power wise or anything from this. just stopped the vaccum leak at the intake so my truck would actually run
