EMISS Light for 1986 Ranger 2.9 auto.
Flat_Bottom
Hello all, first time poster long time reader. I just picked up a little '86 Ranger 2.9 auto 4x4 for a hunting rig and have been doing a bit or work to it for the past few days such as relay replacement, checked electrical and fixing/replacing both fuel pumps. Now one thing that I have noticed is that I never get a check engine light when I first turn the key on. I get the seat belt light that comes on for a bit then goes off but no EMISS light. Now I have been trying to solve this on my own without joining a forum and asking questions but I just dont see any other choice. I have read that some 86-87 rangers did not have an EMISS light wired in, that they were either covered up from the factory or that a bulb was in the socket but no signal wire ever ran to it (this has been written from original owners and such as well). I have read that some trucks will not have a CEL if they were build with the export emissions stuff but ALL US built trucks will have it. I have ran my VIN number and found out that the truck was built in Canada. Does anyone have any further information on this subject? I have to smog the truck (California) in a week or so and don't want to fail by an unknowing technician. Thanks in advance.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
Well, from what I understand (IIRC), CA trucks had the CEL light and non-CA trucks did not (made for sale anywhere else). So, my bet is you are going to have a rodeo with the SMOG guy since 90% of them are not old enough to know the difference.
FYI, my 08 has a label on it saying it was not made for sale in CA. Don't know the differences; but, ........
The white cert label on the rad support should give you some clues about whether or not your truck was built to comply with Cali emissions. It will either say "california emssions" or "federal emissions" somewhere in the block that tells you what year it is.
Also, you can just take the instrument cluster out and look. If it's a Canada built truck odds are very good that the light isn't in there, and the circuit board is just blocked off. If it is there the bulb is probably out.
While I don't have any first hand experience with California emissions testing I have read the sagas of many trying to deal with them, and it seems to me that the best way to deal with having the pass Cali emissions is to just move out of California. Seems to me that course fixes a lot of other problems too.
Flat_Bottom
Thank you both for the replies. The stickers under the hood look like worn out 29 year old stickers but there is a metal ID plate on the firewall just above the blower motor, I will check it out tomorrow. I will be dropping the tank tomorrow afternoon to replace the in tank pump so that will be a good time for me to dig a bit deeper and see if the truck is physically equipped with the light. As for California emissions...you hit the nail on the head. California is a great state being ruined by ignorance, but needless to say Im here and need my truck to pass its emissions. I have noticed that the seatbelt light comes on when the key is turned to on position and then goes off once truck is started...possible wire swap to a different bulb??? Haha, I appreciate the information so far and hope to get solid information to take to the smog guy.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
For the mid 80s, that seat belt light works pretty much like they all did. A light to remind you; but, it doesn't nag you. I bet if you check their is no wiring going the belt latch.
17,949
SW Iowa
The EMISS light isn't a CEL per say, it is a guesstimating device that tries to guess when you have driven approximately 60k miles by the amount of time your key switch has been on and then it turns a light on to remind you that you need to have your emissions equipment inspected. It says you need to check your engine but not because anything is necessarily wrong, just you need to check it because you hit a time limit in a little module that has no clue what is going on with your engine. It isn't a California only thing. In your manual it says how to reset it by pushing a button under the passenger side of the dash.
Uh yeah, how many of us still have those.
SenorNoob
588
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
The manual or the button?
LOL
Mike Tonon
Guest
I think it came on once on my 87 and to me it was just, "How do I shut this thing off so my dash panel looks like it should, stock." lol
Mike Tonon
Guest
Squeeze the sides of the inside of the glove box and drop it down. Look straight up into the dash and if memory serves me right, there is a brown box with a round sticker that says, "RESET". Poke through the sticker with a nail or something similar and hold the button. Sorry I don't remember more of the procedure than that. You might have to have the key in the on position.
17,949
SW Iowa
Someone hid my module on me. It comes on about every 5 years to drive me nuts for two weeks and then must give up or somehow reset itself. I can't find the stupid thing anywhere under the dash where it is supposed to be.
I meant the manual, but yes, those modules have been elusive as well.
When the light on my truck came on my dad just ignored it until the bulb burnt out.
Flat_Bottom
Well actually, my truck came with its original manual. And yes, I meant to say CEL but read a post prior to registering on here that was talking about the EMISS light and I got my terms confused. As for my CEL, it does not have a bulb in the slot. I tore the dash apart to check and low and behold, no bulb has ever been pushed through the plastic. I am going to just run it to smog and hope that the technicians leave it alone and not try to make a big deal about it. Oh, and for the record, my seat belts are in fact wired up. I noticed it when I swapped in some power buckets from an explorer yesterday.
