TSB
03-22-10
- TRANSMISSION - 4R44E - 4R55E - 5R44E - 5R55E - LOW LINE PRESSURE READING AT WIDE OPEN THROTTLE (WOT) - POSSIBLE DIAGNOSTIC TROUBLE CODES P0732, P0733, P1762 - VEHICLES BUILT BEFORE 12/1/2001
Publication Date: October 31, 2003
FORD:
1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
1997-2001 MOUNTAINEER
2000-2002 EXPLORER SPORT
2001-2002 EXPLORER SPORT TRAC
This article supersedes TSB's
03-11-9, 02-13-8 and
02-08-2 to update the model coverage.
ISSUE:
Some vehicles built prior to 12/1/2001 may exhibit the following shift and engagement conditions:
- No 2nd Gear
- No 3rd Gear
- No Engine Braking In Manual 1st.
Out of specification pressures controlled by the transmission main control valve body separator plate may be the cause.
ACTION:
Verify the condition, the main control valve body separator plate may need to be updated to the latest level. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
CAUTION: A NEW SEPARATOR 7Z490 MUST BE USED WHEN INSTALLING THE SPECIAL SERVICE KIT 7M203 OR ADDITIONAL TRANSMISSION DAMAGE MAY OCCUR. REFER TO THE PARTS APPLICATION CHART IN THIS ARTICLE FOR CORRECT SEPARATOR PLATE PART LISTING.
NOTE: THIS ARTICLE DOES NOT APPLY TO ANY OTHER CONDITIONS OR COMPONENTS THAT MAY CAUSE SIMILAR SYMPTOMS AND IS ONLY WRITTEN TO COVER THESE SPECIFIC CONDITIONS.
NOTE: AN IN-LINE SERVICE FILTER IS NOT REQUIRED TO BE ADDED OR REPLACED FOR THIS TSB.
- Verify that one or more of the following conditions exist.
- Low Line Pressure While In Drive At WOT
- No 2nd And/Or No 3rd Gear
- DTC P0732, P0733 Or P1762
- Install Kit (3L5Z-7M203-JA) to update the main control valve body assembly, refer to the installation procedures found in the kit.
- Reinstall the main control by continuing to follow the installation steps listed in the Workshop Manual, in-vehicle service, main control valve body.
- After completing the procedure, verify the condition has been corrected.
- Clear all DTCs.
