Engine Dies
oldskiman
1994 3.0l,4x4,manuals Trans - Intermittent Engine Dies,starter Does Not Engage When Trying To Restart Engine. Several,sometimes Many Attempts To Crank Are Needed Before Starter Catches, Engine Starts And Runs O.k. For Up To Several Weeks Before Problem Happens Again.
Wicked_Sludge
43
Westport, WA
3-point-GO
sounds like a bad starter combined with a bad ignition module
oldskiman
Starter Is New Bosch Reman Unit
Wicked_Sludge
43
Westport, WA
3-point-GO
does the starter click at all when you attempt to start it?
if so its probably your solenoid or wiring. if not, it could be you ignition switch or pushrod.
for future reference, it helps to name things that youve already replaced in your original post :icon_cheers:
