d_man1
- Jan 15, 2010
- 0
- Ford
Need some help guys, Im getting an Engine Misfire, P0306 code on my 02 3.0L Edge... I replaced the Wires, and plugs (set to the correct gap), cleaned MAF. I get a nasty clicking noise at times of engine strain, recently my CEL light came on. I hooked it up to the scanner and got a P0306, Cylinder misfire #6. I have ruled out the ignition system as the coil pack is working properly. Should I check if the injector is the problem by reading impedance load? Should I replace the CMP? please help, I would like to think that the engine can go for more than 122,xxx miles... Thank you
-Don
-Don
