Engine slightly revving while in idle
newnthused
Los Angeles, CA
Ford Ranger XLT
I've cleaned the IAC valve and throttle body. I also change the spark plugs and wires.
My truck starts at a pretty high rpm. Hits about 1500 then after 3 seconds jumps to 17. Warms up to about 1400 then down to 800 after driving around a bit.
But especially when it hits this lower range, like when I come to a stop, the engine revs just a tad like it's huffing and puffing. You can see the tach jostle just a bit. I'm wondering if this crack in the line going to the for has anything to do with it or if this is a problem.
Or if anyone else would know where to point me that would be great. Thanks
franklin2
1,769
Virginia
Bronco II
That cracked line is the fuel line. I am assuming that is just the protective cover, since if it was the actual fuel line you would have a fuel leak.
8,372
That is the fuel line IN, from pump and filter, if its not leaking gas then not a problem
The line above it is the Return fuel line, it attached to the Fuel Pressure Regulator, just FYI
How old is the PCV Valve?
This is a "metered" vacuum leak
It should be changed every 3 oil changes, and cleaned on each oil change
After engine is warmed up and idling unplug the IAC Valve's 2 wire connector
RPMs should drop to 500-600 engine may even stall, either is good, it means no vacuum leaks
If if idle stays higher then either throttle can't close all the way or there is a vacuum leak somewhere
Also you should set/check the spark timing just to be sure its OK
