Engine Ticking, Lets See How Long It Lasts
bilzy7
32
Lynn, MA
4.0 SOHC
It's been awhile guys.
So I always use synthetic oil and go about 5-6k miles between changes. Well about 4kish miles after my last change my engine starting ticking really loud. When I got home I checked and my oil was low. I bought new oil and a filter. I went to go take off the oil filter and it was pretty much just hanging there as 3 twists took it off. I drained the oil and checked, 1 1/2 qts. Holy shit Batman. So the synthetic oil helps but it still ticks and I make sure to keep it at 2k RPM when accelerating. If I go above 2k RPM the engine makes a lot of top end noise like its dry. I'm pretty sure just the top end was damaged.
I drove like this for the past month and just recently became homeless so I'm in a hotel within 0.5 miles of my job.
I really don't know where I'm going with this aside from how reliable this engine has been. Has anyone else had this happen, if so how long did the engine last you?
CaptonZap
Just a WAG, but could it be that a lifter, or two, collapsed? Some Marvel Mystery Oil might help, or not.
CZ
17,867
SW Iowa
The 4.0L OHV (Over Head Valve) V-6 engine found its way in to the Ford Ranger in 1990 and ultimately replaced the 2.9L V-6. This evolutionary redesign of the American 2.9L solved many of the reliability issues that plagued its predecessor. A beefier cylinder head design eliminated the 2.9L's common failure of cracked heads. Hydraulic roller lifters replaced the simple hydraulic lifters used in the 2.9L, which were sometimes overly sensitive to oil contamination, often requiring the lifters to be replaced prematurely. However, one major design fault was not completely eliminated: Valve rockers and upper pushrod tips still received poor oil supply, resulting in eventual wear to these areas, and consequential valvetrain noise as a result of the increased clearance. Required replacement of these parts is common in older engines.
http://www.therangerstation.com/tech_library/4_0_Page.shtml
I thought they still had problems with lifters. Being ran dry sure (or close to it) wouldn't help anything. I would point my finger at them.
On a semi related note the 5.4 in my dd has been making lifter noise now that we are in a cold snap. Never done it in the 11 years prior, changed the oil two weeks ago, it did it once (fluke? you never know) it warmed up outside and quit and then it has done it the last three days which has also been cold, like below 20* in the mornings... I wonder if I got a filter with a bad anti-drainback valve. It just makes noise for about 5 sec after I start it though.
pjtoledo
2,966
Toledo Ohio
Fords
3.0 2.3
maybe put some thicker oil in it. 10-40 or 15-40. might cause a cold weather start issue though.
No members online now.
