Explain scopes to me. Why special "rimfire scope"?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
So I wanted a .22lr. But discovered .17wsm so yea...
I have a few scopes for Ar-15's but never used them, I just have a red dot on mine.
The gun I'm buying requires a scope which I'm not happy about but there's just no iron sight option (savage B-mag heavy barrel .17wsm). I'm told I cannot use one of the AR scopes because the rimfire gun will break it. I can understand the reverse being true but why does a scope made for a gun with recoil die on a gun with almost no recoil?
Do I really need a special rimfire scope? And can anyone explain this in idiot terms?
Also this is what I'm looking at right now, is this good enough? It's a rimfire I'm not spending Leupold money for a target gun...
duffy
19
Hot Springs, SD
Ford Bronco II
The reason for "rim fire" specific scopes is that they are cheaper to manufacture. A 30-06 bolt action will produce a lot more recoil than a .22 LR and therefore need a stronger scope. Also, some rim fire guns have the odd mounting point (not picatinny compatible-my old memory refuses to find the proper name). An AR15 scope that will "mount" will work just fine. I had a Savage B Mag in .17 WSM with a standard barrel and was using a Redfield Hunter ranging scope. Worked well but the bullet was just too light with any breeze. I went with a Howa 1500 in .223......works good out to 500 yards on prairie dogs.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
This, I think a high powered rifle scope should work on a low powered rifle but not vice versa... But aparently from internet research, a normal scope will be destroyed on a rimfire!?
Roert42
5,015
Kintersville, PA
Ranger XLT
4.0 SOHC
The only thing that comes to mind is my trijicon scope that has lines to account for drop off after so many yards.
obviously those lines would be in the incorrect place to used with the wrong caliber.
Parralax is different. An AO (adjustable objective) scope will correct this issue. It will effect accuracy, and probably focus, but not damage the scope.
Air rifle scopes are specific due to the direction of the recoil. Air guns recoil "backwards" compared to powder guns. The way the cross-hair is supported on a normal scope is meant to only brace against the recoil in that direction. Most air rifle rated scopes are braced in both directions.
A "center fire" scope on a rim fire rifle should not break. It may not focus or align correctly, or be difficult to adjust properly because they are parallaxed to 100 yards instead of the 50 yards usually used for rim fires. This may be why some people say they get "broken".
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
You is smaht.
sgtsandman
Aircraft Fuel Tank Diver
12,738
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I find variable magnification scopes easier to work with than fixed power scopes. If you have the opportunity to try both before you buy, do so.
They make 1-4x and 1-6x scopes for .22LR. And don’t go cheap. There is a big clarity difference between a cheap Tasco and a good scope.
89Twincharge
182
Should have provisions drilled for scope mounts you can get weaver or picatinny mounts... as far I know you can use scope for larger rifles on the rim fire with no problem but "rimfire"scopes are usually lower profile which means closer to bore axis.. it all comes down to preference and budget! But any thing more then 9x is kind of overkill because of velocity drop... it will hit like two pumps on a daisy bb gun!
87Ranger4x4xlt
Garrison NY
Rimfire scopes are less rugged and therefore cheaper. Check the minimum focal distance, parallel adjustment before buying/using a centerfire scope ... if the minimum is 100 yds you will have trouble At shorter ranges
