explorer spring swap... did i screw up?
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
did the explorer springs on the rear of my 1st gen ranger. springs were from a '93 4 door
i didn't flip the centering bolts.
when i set them on the stock lift blocks, the bolt & nut on the bottom of the spring went right into the centering hole, no problem. is there any other reason to flip the center bolt other than fitment into the centering hole on the lift block?
bilzy7
32
Lynn, MA
4.0 SOHC
I thought you flip it mainly cause it'd be attached to top of axle not bottom so naturally you'd flip... I thought it was more of a fitment issue then anything...
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
You don't want the axle shifting around loosening the centerpin nut. I'd flip it regardless of the nut fitting in the hole.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
this
the snugger the fit, the better. when you have play, you're gonna have problems.
the center pin from my EX springs was rusted pretty darn good, couldnt get it off to save my life. i hacked it off with the angle grinder and put a new one in. got them pretty cheap at the bronco graveyard if you need any.
17,953
SW Iowa
If the axle is flopping around in the u-bolts you are screwed already. If you have in cinched down right it won't know where the pin is and it won't care. Like a wheel with a hub-centric rim the clamping force is what holds it in place.
The centering pin is so you get the axle put on straight.
chrwilkins30
6
Mishawaka, Indiana
2.9
this
same her i cut it with a grinder and replace with grade 8 after trying to put it in the hole on the perch the head was to to big. easy fix was to grab the grinder and round the head off that way you don't have to wait on part orders
