F150 Coil Spring Swap to Ranger
JakeC
Could I swap the Front Coils from a F150 to my 1989 Ranger XLT 4x4? Would it make it sit higher? Any bad side effects of this or suggest ways to do so?
Irokranger93
Michigan
3.0L
Gives a 1½-2 inches more in height ---You could use its coil spring 150 on your ranger very easy to install
redrangerjim
Fulton, MS
FORD
I've thought of trying the same thing. Does is matter if the coils come from a 4wd or 2wd F150?
alwaysFlOoReD
5,129
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Here's a link to a guy that did this;
http://www.therangerstation.com/forums/showthread.php?t=78490
I've done some research on this and have come up with the '78-'79 full size bronco spring as a possibility. It has 271 ppi. spring rate compared to the rangers approx. 430 ppi. It's about 4" longer than stock ranger.
From left to right;'79 fsb, unknown f-150, unknown f-150,'87 stx highrider [I think it's 2" longer than stock?], '79 fsb
I'm going to install this in my truck soon so I don't have any actual numbers to give you on how much higher this spring will give you.
Here's another link with good info, it's in the tech section;
http://www.therangerstation.com/Magazine/Fall2003/F-150_coils_for_your_V8_BII_or_Ranger.htm
Good luck,
Richard
r1hatman
4
Knoxville, TN
2.8
I got ones off a 4x4 89 If I remember correctly. I love it. Stiff as a tank though. remember to get the spring retaining clips and the shocks while your there.
93 4x4 ranger
Burlington, IA
I'm in the middle of doing this swap and was wondering about what people have done as far as the shocks for it. I know in the read up he says he used F-150 with a 2 inch lift anyone used some different?
irishblessing
Guest
i used f150 springs as well i bought them from autozone there Gabriels for an 88 F150 which the guy behind the counter said were the same part number for the 4wd ranger the shocks are the right length but i had to push the rubber peices out of the shocks and get new oned because the ones that came with the shocks wouldn't fit onto the shock bolts.
here is a thread from my results
http://www.therangerstation.com/forums/showthread.php?t=83591
93 4x4 ranger
Burlington, IA
There was no way I could of used a stock F-150 shock with mine. I measured the one of my dad's 89 and they were a little more than an inch short.
irishblessing
Guest
was your truck jacked up in the air when you checked i had to jack mine up a little bit to compress the spring to put the shocks on
Countryboy91
Zanesville, Ohio
2.9 stocker
How much lift was gained? Any brackets or etc needed?
