F150 coil springs results
lgrasseth
87 ford ranger
The f150 coils gave me probably 4 inches over stock, and the explorer leafs gave me about 2 inches.
irishblessing
Guest
did you have to use f150 coil perches or did you use your stock ranger perches?
r1hatman
4
Knoxville, TN
2.8
I used my stock ranger perches.
r1hatman
4
Knoxville, TN
2.8
Gary101386
Oswego IL
2.9
i plan on doing this on my 89. What year F150 coils should i look for?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
any ttb coil. the 100 will ride better and give less lift...the e series sometimes will be beat more and offer less lift and better ride
best results for me include e or f arms with relocated radius arm brackets
the 150 shocks were too short for me so i put stud extenders on the shocks with regular ranger arms....when running the top shock mount f arms they are at a odd angle but work great
peclarkjr@msn.com
I also have the f-150 springs on my truck. I still need about 2 inches of lift to fit 35's. Does anyone know if I add a coil spacer if I should get the one for the f-150 spring or the stock ranger. I would think the F150 but I don't know for sure because the spring is mounted on stock Ranger components.
Thanks,
Paul
doublecranch94
Does it matter what year f150 fro the springs? and if so what year would work best with my 98?
Did you read the last page? Any ttb year, so like 83 to 96, they are all pretty much the same.
