Factory Ford first gen winch mount
85_Ranger4x4
17,962
SW Iowa
Anybody ever even seen one? Better yet do you have good pictures of one?
85_Ranger4x4
17,962
SW Iowa
Roert42
5,022
Kintersville, PA
Ranger XLT
4.0 SOHC
I like the application of leaf springs to help push the bodies under the truck without messing up the bumper or banging up the diff.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Sure would like to find one of those Warn winch bumper 85Ranger4x4, every time i go to the bone yard they have taken all the aftermarket goodies off it seems.
85_Ranger4x4
17,962
SW Iowa
If ya, sneak up on two of them let me know. :icon_thumby:
I am currently scheming on how make one inspired by the Ford/Warn ones.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Can't get any bites on flea bay either. Wont a winch in worst way, sure would come in handy. Guess ill take the front bumper off and weld up a receiver behind. Seen some already fabricated on the web but not for a 1987 ranger.
85_Ranger4x4
17,962
SW Iowa
Cradles for a receiver are cheap.
I snagged one of these to build my grille guard off of.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I got a warn winch and mount plate as a labor barter from an 04 f150. Made my own bumper to mount. Crude but works well. Still needs some finish work.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Thats nice work, very functional. Is that 4X2 inch tube steel tw205. Cant see the side well. Looks very interesting. Did you weld or use the OEM bumper bolts to the frame. Dirty
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Thats nice work, very functional. Is that 4 inch tube steel tw205. Cant see the side well. Looks very interesting. Did you weld or use the OEM bumper bolts to the frame. Dirty
Thanks. Yes it’s 4” x 2” steel tube 3/8 thick. It’s a heavy beast. I made brackets from 1/4 steel plate welded to the 4x2 that mount to the frame using 4 existing holes on each side of the frame. 3 on the vertical face and one on the bottom side. Attached with 1/2” grade 8 bolts. It’s currently off the truck as I’m trying to fabricate a brush guard onto it. I have to use my cherry picker to put it on.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
I would say around 185+ with winch. Measure the shock and spring height before you reinstall it. I would like to know the travel distance. Dirty
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Called harbor freight and they have the one Ranger4x4 found. Going to look at it tomorrow. Looks like i can snake it behind the bumper and use a slot in the bumper for the fair lead. Dirty
85_Ranger4x4
17,962
SW Iowa
I looked into that, I just don't have the room there in my truck.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
My AC cooler has been taken out and I have the 2.9 turd not a 5.0. That's why I ask tw205 to measure the deflection in the springs and shocks. He has a 2.8 I believe. Has to be geared right its running 33's. I'm pretty educated block and tackle to strengthening the pull rate, "aint nuthin but lift verus drag" right. I wont be pulling on anything large and i wont to place one on the rear to. Dirty
85_Ranger4x4
17,962
SW Iowa
3" body lift, factory 4.0 rad on factory mounts and my 5.0 sits higher than the 2.8 did. 🤷‍♂️
