Feul tank relocation?
Freerider487
I have a 1990 xlt 4x4 2.9l pretty much wanna pull out feul tank and relocate in the bad on the back wall of bed
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
do it.
depending on what setup you have you can make a hole and route the lines up and make two chains to bolt it down to the bed.
if you dont have enough you can make jumper lines easy enough or convert the in tank pump to a mustang pump and run a new line right to the high pressure filter relocating that in the process by passing the frame pump to make it easier to change unless you already have the single hp pump system....i have seen both on a 90..
luke
4
Silverdale WA
you should do it. if you move your tank to the bed, you'll have room for dual pipes :)
Freerider487
I mean the only reason I'm doing this is to protect my feul source cause I go to Rausch creek and the rocks are unforgiving lmao I wanna keep the original unit in the tank I shouldn't have a probem just extending electric and feul lines right
