Finally put together my stereo system
fordman49450
Michigan
I'm going for sound, not head bursting bass. I am running a JVC-AR860 Arsenal Series Deck 55X4. That is running 2 6.5 Infinity Component 6002i with adustable Tweeters. It's running 2 5X7's Infnity Component 6802cf with adjustable tweeters as well. For a little bass, I'm running a Audiobahn A8000T 1600W amplifier fed by a 1.2 farad Kaption Audio Digital Capacitor. powering 2 MTX 7000 10" subs in a sealed box. I just need to get everything installed and make a panel for the amp and capacitor.
Pistons23
Fresno CA
2.5
geez, sounds like your going to be asking your headunits amp to be working real hard
ironman
louisville kentucky
sounds like a nice setup you are going to be using a fuse panel box for everything right.where did you have you 5x7 going?
fordman49450
Michigan
All run with 4ga stinger wire with Fuses on both ground and power
Soloassault
just a thought
first ditch ur cap and get a small kinetic battery, u will be much happier in the end, also i would suggest using a small 200~300 watt 4 channel amp for your mids and highs. lastly go ahead and invest in a 0awg wire kit. just your amp for your bass will exceed the capabilities of 4awg wire. and from my experience, you might consider building a larger vented type box for your subs, it will require less power to get the same about of sound resulting in less load on you batteries/alternator,
