Five Lug Ford 9"
koda6966
61
The green part of NY.
2.9
They made them right? Older F150's were 5 lug instead of 8 IIRC and still had the 9.
Hopefully I'm right, my JY has a sweet sale going on for 5/6/7 lug axles but 8 is still the regular price. I'll take a 5x5.5 9 if I can find it. :D
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
All factory 9" axle's in truck's are 5 lug...
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
That was all he had to read to be able to race to the JY. There better be pics of a good find.
koda6966
61
2.9
lol, I thought some were 8 lug? Jeez, I'm excited now. :D
koda6966
61
2.9
If you can't tell, I'm new to the 9" world.
koda6966
61
2.9
Are there any years I should be particularly interested in? I don't mind added width, I'm staying with full width axles. I'm more concerned if a certain year came with better shafts etc etc.
Also, I'm planning on eventually doing a disk swap to the axle. If that changes anything.
cyclegrip
They are pretty much all the same aside from bearing sizes
Sent from my DROID2 using Tapatalk
alwaysFlOoReD
5,132
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
There are 9" from cars and trucks and station wagons all the way back to 1957 and maybe earlier. A lot of the cars and wagons come with 5x4.5" stud spacing. An old timers trick to fit wide tires was to take a rear from a full size ford 1957 thru 1959 as it was the narrowest backing plate to backing plate from the factory. They were IIRC 28 spline axles. Add a shim to the side gears and you had cheap posi. Some pumpkins came with 4 spider gears and were preferred for the extra strength if adding shims. An old truck with a 6 cylinder would have deeper gears; 4.56, 4.10, 3.73. All this info was gleaned from hot-rod mags of the day and from personal experience; I installed a 9" from a 58 Edsel and a drop out pumpkin from a mid '60s truck with 4.10 gears and did the shim mod and stuffed it under my '68 Torino with a stock '68 Merc. Marquis 429/c-6 combo. It was fun, did 105 mph in the 1/4 and got 17 mpg imperial ~ 13.5 mpg us. I did this in the early '80's. And I still have the Torino.
Richard
