FM-145 Shifter Sloppy
Hitchner2009
Silverdale, Washington
Hey guys, so my shifter for my Fm145 is sloppy, the shifter acts likes its in neutral even when in gear, and what I mean is I can shake it around back and forth in gear and it moves alot instead of being tight. Any idea as to what causes that? I swear I read somewhere about there being a bearing on top of the trans under the shifter, but I cant remember.
On the end of the shifter is a teflon ball. It has broken. Replacement parts have been unavailable since sometime in the mid 90s. Sorry for your luck.
Hitchner2009
So then to the junkyard if I can find one. Can I just pull the housing off and replace it if I can find one?
Yup, the pyramid housing and the shift lever.
Hitchner2009
Alright cool. I have a Ford Master tech in my shop that knows about it, he said hes had some luck with shimming it to take the slop out due to unavailabilty of parts. Had any luck or done anything like that??
Hitchner2009
So i pulled the shifter housing off last night and the teflon ball was intact. Moved the shift fork back and forth and there is absolutely no play like in the shifter. So i guess its not as bad as i thought, maybe thats just how it is?? No broken parts or anything. There was a plastic cup thing that was under the boot with a washer on top of it, but it was loose, that moves up and down a little if i move it, idk what the heck thats for maybe thats a problem? i couldnt pull it off because there was a nub on the shifter that stopped it from coming all the way off.
