- Oct 10, 2011
- 1
- Arkansas Ozarks
- Ranger
- Engine Size
- 2.3
Since I'm a couple of months shy of 70, installing my transmission in my driveway solo isn't as easy as it used to be. I found a method that works and doesn't aggravate my sore back. With a pry bar, lift the trans a little and shove a wood block underneath. Fasten a chain around the trans and up through the floorshift hole. You can put a jack under the chain (inside the cab) and it lifts the trans nicely. This also involves using wood blocks and a floor jack and much fiddling around but there is no heavy lifting. It also takes much longer than if you were able to muscle it in.
I hope this helps, it sure helped me.
Jim
Jim
