ford fuse box diagram?
C00T3R
I've been looking for one on the internet, I need the diagram for the intereior fuse box if some one can find me a link that would be great. Thank you guys
snoman6115
Weston, WI
v6 4.0
if hte 97 is the same as the 98 i can get u a pic but i think 97 is under the dash by the hood pop latch right? or is it by teh door
C00T3R
its by the door
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
It can be found in the chiltons book.
1-power mirror
2-airbag system/blower relay
3-parking lamps
4-Left headlamp
5-OBD 2 system
6-Not used
7-Illumination switches
8-Right headlamp/ foglamp system
9-ABS system
10-Speed control/GEM sys/Brake interlock
11-Warning lamps
12-Front washer sys
13-PCM sys/stoplamps/4WD/ABS/Speed control
14-ABS system
15-Airbag system/alternator
16-Front wiper
17-Cigar lighter
18-A/C system
19-Ignition coil/PCM system
20-Radio/GEM sys/Anti-theft
21-Hazards
22-Turn signals
23-Not used
24-Starter relay/anti-theft
25-Speedometer/GEM system
26-A4lde Trans./backup lamps/DRL system
27-Underhood light/Map lights/glovebox light/dome lamp/visor lamps/4x4 system
28-GEM system
29-Audio system
30-32-Not used
33-High beam lamps
34-Not used
The fuses will be numbered on the red part of the fuseblock next to the corresponding fuse. :icon_thumby:
C00T3R
Damn, I checked 12's not blown. My windshield wipers quit working and I checked the technical library and cleaned out the switch and that didnt work. So, what could it be
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
Try 16, that's your wipers, 12 is the washer pump. :icon_twisted:
C00T3R
16s not blown either...
River
2.3L
So I see nothing labeled brake or stop lights in that diagram
