- Oct 1, 2021
- 2,776
- corpus christi, texas
- ranger edge
- Engine Type
- 3.0 V6
- Engine Size
- 183 ci of tire shredding power
- 2WD / 4WD
- 2WD
- Total Lift
- none
- Total Drop
- none
- Tire Size
- 235s
- My credo
- drives a stick shift ranger
I wanted to upgrade my diff cover to something that looks cool but i didnt want to spend 200+ bucks. I like the ford motorsport cover but i don't like the price.
So, i ordered this diff cover from amazon. The ad said it fits my 04 ranger 8.8 but it needed some work to make it actually fit.
NEW Aluminum & Finned Rear 8.8" Axle Differential Cover Fit For Mustang DR3Z-4033-B https://a.co/d/ckuc9ga
But the mounting bolt holes didn't line up because the ranger gear set has a tone ring that the speedo or abs reads inside the diff.
See it? Its the thin toothed gear on the left of the large gear.
My amazon cover had cooling fin inside that hit that little gear. And i unfortunately don't have a pic of it before i started working it. I thought i did. So you guys will have to imagine it from this picture. I circled the fin in red that hits the gear. This pic is from the amazon ad.
Anyways, i ground and than test fit. Still no good
Then i ground and tested again. No go.
Then i ground and fit a few more times till it did fit.
And finally!!! It clears and nothing rubs
I filled it with 75/90 synthetic, 3.5 quarts and it needs a little more so i need to get another quart tomorrow but its good.
Now my cool guy 8.8 with 4.10 is happy
