pcsstoll
- Sep 8, 2020
- 0
- Bellevue, WA
- Ford Ranger
Hi, I'm pretty new to fixing vehicles but am learning fast. I've had this 86 ranger XLT 2WD for a little under a year and been fixing small things here and there.
I noticed recently that my knock sensor had been unplugged. Truck has been running well but I have no comparison. I plugged it back in and didn't notice a difference in how the engine performs. I did an error code test and received a 25 error code. I traced this down to be a knock sensor issue.
I tested the knock sensor and can't tell if it is functioning or not. I tested for resistance and I tried to do a knocking test looking at Volts AC response. Either this thing is tricky to test or I'm doing it wrong.
I read in the ranger forums of people suggesting the sensor may be too sensitive and pick up unwanted noise. Some one mentioned replacing the computer with an '88 but I'm not sure what other aspects can be affected by this. Also I can't seem to find a replacement for less than $200?
Question: Should I replace the knock sensor for $200? Any tests I should retry or do? Are there better questions I should be asking?
Thank you for your help in advance,
Paul
Paul
