FPR tapping..is this normal?
BAYNE
I have a 84 ranger with a newer 2.9v6... the intake manifold gasket was junk and leaking so i replaced it.. all went together easy... but now that everything is quiet ''if you will'' i can hear a tapping... i did the old ear to the screwdriver test to pinpoint where it was coming from and its definatly the FPR making the tapping noise... the truck runs great and no starting issues.. just wondering if this is normal or a sign of the FPR starting to fail
There isn't anything in the FPR that should really be able to make that kind of noise. You were probably hearing a loud injector telegraphing to the FPR.
BAYNE
thats what i figured.. it just sounds like its the loudest on/in the fpr
BAYNE
so is it normal.. or alright to have a loud injector ... this is my daily driver so just want it to keep goin...lol
Tedybear
Firefighter
13
1994 Ford Bronc
5.8v8
Failing is easy. Everyone can do it.
You can use the 'screwdriver' method, along with disconnecting each injector plug to locate the exact one causing the loud 'click'. But in all honesty? These engines are not happy unless they have a bit of clicks and what not.
If it makes you feel better? Look into a replacement injector. Get the ID number and do an eBay search for a cheaper replacement then the parts houses. (Check the 'feedback' on the sellers profile to ensure they are decent to work with)
(and yeah....ours sounds like nickles in a tin can rolling around with our 2.9. It needs injectors replaced as they are leaking again. But it still runs and drives okay)
S-
BAYNE
nice thats all i needed to know ... mine arent leaking just noisey i guess... they can tap away then... thanks everyone for the info
koda6966
61
The green part of NY.
2.9
Off topic, but I read that as fapping.
Anyway, I agree probably just an injector. I wouldn't worry about it unless it gets significantly worse.
