Frame Swap for 1984 Mazda B2000 project -- What might work?
lonelyshark
Philadelphia
Mazda B2000
Hi there -- so I've got a 1984 Mazda B2000 with only about 30k on it. It's in truly incredible condition inside and out...... except for the frame, which is rotted badly.
I'm wanting to find a vehicle with a decent frame and tackle the frame swap as a project. But to start, I could really use advice on what vehicles should have the same/compatible frames so I can start keeping an eye out for a good candidate.
Would a Ranger from around that time do the trick? Someone near me happens to be selling an '85 Ranger with a solid frame right now. Good option or no? The workshop manual for the '84 B2000 lists the wheel base as 2715mm and the length at 4445mm (it's a standard body not a long body).
I'd love to make this little truck road-worthy again. Any one got ideas?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Ranger and B series are the same truck. Any frame of the same type (2wd and 4wd are different as are different cab configurations and bed length) from 1984-1985 would work. (Later years may be the same as well but I think they got slightly bigger in 86)
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Ranger and b-series are the same truck within certain years. I got burnt on that but cant remember exactly what year b-series i had. Iirc it was 1987.
*ended up selling it for double what i paid...
lonelyshark
Philadelphia
Mazda B2000
Dang that's a cool build! And yeah, I'm not sure what years the B2000 was a rebadged Ford Courier and what years it was a Ranger (if I've got that right?) When you say you got burnt, how much of a difference was there in terms of the frames?
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Totally different frames. SLA vs TTB. Six stud wheels. Nothing swaps.
I "think" 1990 to 97 were the years that Ford and Mazda were the same.
89Twincharge
182
That year b is not same as ranger.... I still want one though
Colin
182
ON Canada
Mazda
1994-2011 are rebadged Rangers.
Op yoru best bet is either a full custom frame, or some sort of hot rod chassis kit.
You might be able to adapt a regular ranger frame but you'd probably have to move most of the mounting points/crossmembers. Potentially shorten/lengthen certain sections
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would probably get the specs for a standard cab short bed Ranger... I'm thinking they have to be pretty close. Those specs should be in the Tech Library. Alter it a bit if you have to. Then build mounts to set the body on the Ranger chassis.
EDIT... I would look at a 4x4 chassis... just because. I would also just use the Ranger powertrain... just for simplicity and I could have a 4.0L.
That body looks pretty nice... but seems most of those really rotted away. It would be a cool unique truck completed. Good luck on your journey.
And Welcome to TRS...
89Twincharge
182
Dont know where your located but there's a guy here in NC with 15 or so in his yard hes trying to sell since his father passed
lonelyshark
Philadelphia
Mazda B2000
Oh woah, thanks for the heads up!
Pantharen
4
Northern Vancouver Island, BC Canada
Subaru Impreza
2.5L H Naturally aspirated
1.5"
205/55R15
Licensed Security guard
Pre-1994 Nothing Mazda / Ford is the same. They are completely different vehicles. Mazda prior to 1994 was made in Japan 100%
