fatt_owl2.9
- Oct 8, 2008
- 0
- Ford
- Engine Size
- 2.9L
I've had a seemingly intermittent issue with my truck for as long as I've had it, which has been exactly a year and about 14k miles. What I'm wondering is, is the framerail fuel pump supposed to run every time the key is turned? Mine doesn't always. There was a period where the problem seemed to go away for a few months, and my truck would fire up flawlessly every time. But then it'll come back, and sometimes I'll have to turn the key a half a dozen times or even more before I hear the pump buzz and my engine fires up.
There's a couple other intermittent issues that seem to come with it....the first one happens only when the truck is cold, I'll turn the key and hear the pump buzz, start the engine, it will fire right up and at the very second where the engine is supposed to settle down to its idling RPM, it will fall right on its face and stall. I'll have sometimes crank the engine 3 or 4 or even 6 times before it will finally run.
The other issue is that sometimes the engine will start, but idle real sputtery, like it's missing really bad, I'll try and give it some gas but nothing happens, it won't rev at all, and after a few seconds it'll sputter out and die, and I'll have to crank it a few times until it fires up and idles/runs smoothly. This clearly seems to me like the framerail pump is not always doing its job upon startup. Could these also be symptoms of a crapped-out FPR? Once the engine is started and running normally it drives like a dream, always pulls smoothly and never has any hesitation or sputtering. The startup issues just bug the crap outta me lol.
I'm hoping maybe this is just a sign the rail pump is on it's way out, and not indicative of other possible electrical issues, like ECU signals or anything like that. When it comes to electrical i'm totally retarded, and dread facing any such issue. I guess I can try replacing the pump but something tells me it's a friggin' expensive part, plus I've crawled underneath there and looked, the pump is covered by a thick metal scuff protector box, and I can't figure out at all how to get to it.
Thanks for any advice and insight guys.
