Frequently Asked Questions (FAQs)
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,803
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Tech Library
Don't forget to check out the Tire / Wheel / Brake section of the Tech Library.
TIRES
Whats the largest tire I can fit on my Ranger/Explorer/Bronco II?
Stock trucks:
4x4 Rangers & all Explorer & Bronco II:
For '83-'92 4x4 Rangers and all Bronco II, you can fit up to a 30x9.50R15 or 235/75R15 using the stock rims.
On '93-'10 4x4 Rangers (and all Edge/Trailhead models), a 31x10.50R15 or a 265/75R16 will fit, depending on if you have the 15" or 16" stock wheels (16s are common on '98-'10). There is some variation in torsion bar settings from the factory and some trucks sag in the front after a while so you may need to turn the torsion bars up to level. '08+ Rangers have lower torsion bar keys and rear blocks from the factory and larger tires might rub slightly.
On '98-'10 4wd Rangers a 32" or narrow 33" can be fit with a 1.5" torsion bar twist. 33x10.50-15 BFG or 285/75-16 will fit on the stock rims with slight rubbing on the inside.
On '95-'01 Explorers and '01-'05 Sport Tracs you can fit a 32" or narrow 33" with a 1.5" torsion twist and Warrior #WAR-153 1.25" rear shackles. A 265/75-16 will fit fine, a 285/75-16 will fit with 1.0"-1.25" spacers on the rear wheels.
'91-'01 Explorers (all) should be able to accommodate a 31x10.50R15 or 265/75R16 on stock rims.
2WD (Ranger):
83-'92: 225/75R15 will fit using a 15x7" wheel with a stock 4.0" backspace. Some reports of 235/75R15 fitting have also been posted.
For stock 14" wheels, a 27x8.50R14 or 225/70R14 will fit.
'93-'10: 235/75R15 will fit on the same wheel described above. 28x8.50R14 or 235/75R14 for 14" wheels. 225/70-15 tires were standard on many 98+ 2wd Rangers.
235/70-16s on any 16 inch ranger, explorer or mustang rim will fit. Stick with a ranger or explorer rim though because with the mustang rims it will rub the back a little. Other then that clearance is fine and it will sit you a good 3" over stock.
Lifted trucks:
Tire fitment on lifted trucks can vary due to actual lift height and wheel size used.
In general, a 31x10.50R15 will fit on '83-'92 4x4 models with 3" lift, 33x12.50s with 6" lift.
On '93-'10 4x4 models, 33x12.50 will fit with 3-4" lift. 35x12.50R15 will fit with a 6" lift. Slight rubbing may still occur with 35x12.50 when offroad, however. Very slight fender trimming can eliminate it.
Generally a narrower rim (15x7 or 15X8) will let you fit a larger diameter tire than a wide one (15x10).
For lifted 2WD Rangers, 31x10.50 will fit with 3" lift. With 5.5-6" lift, a 33x12.50 will fit '93-'08 models.
These figures are somewhat on the conservative side. You may be able to go up one size larger than described here if you don't mind a little bit of tire rub. Some forum users here run 32x11.50s or 33x10.50s on their stock '93-'97 models, and 285/75R16 on '98-'10 models without problems.
WHEELS
What size rim do I need for ____?
Many rim questions can be answered here.
Many older 2wd Rangers were equipped with 14" wheels. Any Ranger or Explorer 15" or 16" wheel will fit on a 2wd but most of the 14" rims will not fit over the front hub on a 4wd. Also it is getting harder to find 14" tires and not really any cheaper when you do. Consider buying some used 15" rims and you will have a much wider choice when it comes to buying tires.
31x10.50-15, 32x11.50-15 will fit on a 15x7 or 15x8 rim. A 15x10 is really too wide. A 33x12.50-15 will fit on a 15x8 or 15x10, a 15x7 is doable but really too narrow for a 12.50 tire.
A common issue concerning aftermarket 16"-and-up rims is that most of them have a GM-type positive offset (even if they have a Ford bolt pattern) and the tires may rub on the inside. Depending on the tire size you don't want more than 4.5" backspace at most and usually less than that.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Edit; I've deleted all posts asking questions or with no real data!!
^^^ Thanks for answering but the point of a faq is for people to do their own research. If the person above you had actually read the faq he wouldn't of had a question to ask. If the faq doesn't answer the question then please post your question in a new thread.
Thanks for understanding,
Richard
Ranger Dave (B25)
134
RFD/BNA/PHT
'10
Don't vote Democrat.
No sir, that's incorrect.
I have a set of Splash wheels bought for my B2500 (2WD) for winter tires, but they wouldn't fit on the front hubs. Ranger Sport wheels however, would.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
More data please. What years were involved?
Ranger Dave (B25)
134
RFD/BNA/PHT
'10
Splash chromed-steel wheels were from a 94-95 model, and have 2.5 inch center hole. The Sport alloys from later model trucks have a 3.5 inch center hole and fit my '99 B2500 (and 2010 Ranger) perfectly.
Now, will late-model (2010) Ranger steel wheels fit my '99 B2500?
