French-connection
- Aug 12, 2017
- 1
- SC
- Ford
- Engine Size
- 4.0
Hi.
I need to replace my front carrier since my ring and pinion are bad.
I got my hands on an axle that seems to be missing the inner shaft on the passenger side, including the bearing.
https://ibb.co/gUnvn6
Does this look right? Could I just use the shaft and bearing, or new bearing from my carrier assembly and install it?
The housing seems to be the correct shape and I don't know if there was a version with removable axle shaft.
Am I missing something?
Thanks,
Olivier
Thanks,
Olivier
