Front end noise
hoser1000
R@ng3rX48!
Ranger XLT 4x4
I have a 2011 Ranger XLT 4x4 4.0l with 186,000 miles and it has a rotational noise coming from the front end starting around 20-30 mph. If I coast at that speed you can hear it pretty good. I don’t feel any vibrations and the steering doesn’t pull to one side or the other. I though it may be the wheel hub but I’ve just replaced both and the sound is still present. Any suggestions are much appreciated.
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
Welcome to the site. Did everything get tightened back up? Is the noise both sides or just one?
hoser1000
R@ng3rX48!
Ranger XLT 4x4
Everything was torqued to spec. It sounds like it’s coming from the drivers side but I put a GoPro underneath and could only hear it in the passenger side when watching the video.
hoser1000
R@ng3rX48!
Ranger XLT 4x4
Brought it to a shop for further diagnosis and they said it’s someone from the transfer case or the front differential. I guess next step is to remove the front drive shaft to try and isolate the noise between the two.
