Front lights do not turn on
nerij
Mexico
Hello pals
I need some advice regarding to my front lights, they just won't turn on, all the rest will turn on normaly, I check into all fuses but all seems to be ok so i do not know what else to check.
Original_Ranger84
20
2.8L, 3.0L
Its probably your multi switch thats on your steering wheel, it controls the high and low beams along with window wipers and turn signals. My friends just went out on his 93 I am trying to find a JY replacement cause the store wants like 200 bucks for it.
It could also be the pull knob/dimmer switch too...
nerij
Mexico
I will take a look into the multi switch, hope I can find the failure cause otherwishe will have to go a auto shop.
Thanks for your advice... is highly appreciated
Original_Ranger84
20
2.8L, 3.0L
Yep not a problem.
So when you pull out the knob all of the other lights work? and they dim when you change the dimmer?
If so then it is more then likely your multi switch. but try and find a pick an pull yard.
No members online now.
