Front output yoke on BW1354 (98 - tulip)
Macneil87
5
Sudbury, ON. Canada
Fellas,
I am building a 98 Ranger short box reg cab for some weekend fun. I am doing a solid axle swap and currently, I am in search of a front output yoke/shaft option.
I’ve tried to search without much luck. Does Neapco still make the front fixed yoke adapter that bolts up to the stock output? I have tried getting in contact with them and a few dealers without much luck as of yet. That would be the easiest alternative. Would an output shaft from an older (pre 97) bw1354 work? I don’t mind having to split the case to swap in a new shaft, however I haven’t found any sound proof that it will be a simple swap as of yet.
I am trying to not spend a fortune on this if I don’t have to. I’d rather spend money on something else if possible.
If anyone has an old yoke/shaft kicking around that could be of use to me, I will purchase
located in Northern Ontario, Canada
Thanks!
snoranger
Professional money waster
ASE Certified Tech
TRS 25th Anniversary
13,785
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Yes... you can swap the front output shaft from an early 13-54 into yours. It can be from either a manual or E-shift, that doesn’t matter.
SenorNoob
632
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
^^ That's a good thing to know. Too bad manual transfer cases got rare in the later years.
2 bronco 11s
68
kentucky
ford bronco 11
I have a1993 1354 I am not going to use. If it will fit I will gladly sell it. I use the 1350's.
