AndyB.
- May 26, 2014
- Reaction score
- 146
- Location
- Cincinnati, OH
- Automatic
Yes, just lights aside from the fuel gauge.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
13.8vWhat did you use as a test bench voltage , 13.2 v ?
I clearly need to do this as my fuel gauge reads well above F when the tank is full.I zeroed the trimmer on the instrument voltage regulator until the needle was on F.
I tried three different sending units and installed an oil pressure gauge (which I believe came with the truck). The electrical units always read in the lower part of the scale. The pressure gauge read 60+ psi except when the engine was really hot (like when I was trying to diagnose a failed electric choke). I removed the pressure gauge because it wouldn't stop leaking and I was afraid the cheap plastic oil line would pop out and the oil would exit the engine. None of the electric sending units leaked even though they seemed to read low. Maybe a braided steel line and that Bosch pressure gauge is a better solution. At the time, I had other fish to fry. I was also using the oil viscosity that the engine rebuilder recommended. As you opined, a thicker oil might be in order. HTHThat could be a sender issue though since this truck has been through multiple hands and god knows what parts were used after the engine rebuild.
I still think I'll look up which model of oil pressure sender I used on my V8 truck and install one of those. It got the gauge to read in the center. Glad to see you're still on here. Are you still in the Ranger/BII game? Looking at buying another one?I tried three different sending units and installed an oil pressure gauge (which I believe came with the truck). The electrical units always read in the lower part of the scale. The pressure gauge read 60+ psi except when the engine was really hot (like when I was trying to diagnose a failed electric choke). I removed the pressure gauge because it wouldn't stop leaking and I was afraid the cheap plastic oil line would pop out and the oil would exit the engine. None of the electric sending units leaked even though they seemed to read low. Maybe a braided steel line and that Bosch pressure gauge is a better solution. At the time, I had other fish to fry. I was also using the oil viscosity that the engine rebuilder recommended. As you opined, a thicker oil might be in order. HTH
I have owned a bunch of Mustangs in my day and recall the oil pressure sending units from the 289/302. IIRC, its the same unit as the one that is (was) on the engine currently; Standard Motor Products, PS60. Even the Motorcraft part number is the same; E6ZF-9D290-CA. Maybe I got three duds?I still think I'll look up which model of oil pressure sender I used on my V8 truck and install one of those.
I now own a 2011 RCSB 2.3/auto in Oxford White. Just installed a sliding rear backlight on it over the weekend.Glad to see you're still on here. Are you still in the Ranger/BII game? Looking at buying another one?
