Fuel line replacement.
richard booth
28
Tacoma wa
2.9 for now.
Question is, what are the connectors for my 88 B2 fuel system named? I am going to replace the old plastic lines and do away w the hi pressure pump and run a intank pump and I want to get the fittings that will fit correctly. Thanks.
8,374
Rangers use Nylon fuel lines 5/16th
Ford used Bundy Type fuel line connectors, AKA Quick connect/disconnect fittings, although that name is VERY misleading, lol
Dorman has replacement fittings
While the hose will be 5/16th the connectors can be 5/16th OR 3/8ths
Unless someone has done a 1988 Ranger/B2 recently and knows the size at each connection you need to see if you can find old posts that have it
richard booth
28
Tacoma wa
2.9 for now.
Ron D, you rock! Thanks for your help.
