Thanks IM, there is no filter in the cannister because I had it apart before I knew where the "real" filter is and when I replaced the gas tank I got the pump that was with it because it looked pretty new,I know there are two. Yeah,I can hear the pump run and shut off. It has had a problem for awhile with starting again if I killed it on take off. It is still running but takes spells where it misses real bad and it's getting worse quickly. Last time I drove it was Sunday coming home from church (about 20 minutes) and it missed out almost the whole way home. The main reason I believe it is the high pressure pump is that I ran it low on gas and it started missing when I turned a corner like it was out of gas and it runs decent at light throttle then misses when I try to give it gas. Thanks again IM.
I had very similar experience with mine....I got
much more reliability when I opened up the gas tank...to replace the "in tank" pump....the big issue for mine was the short piece of rubber hose between the pick-up sock & pump to the stem pipe, which sends fuel out to the tank. this short section of rubber hose was about 2-3"....and was completely gone. shucks the fuel pressure even tested OK, toward the bottom of the spec but ok...If I recall correctly, 31-32psi
I could have replace the hose and
maybe gotten by on the cheep. BUT I had already bought the fuel pumps...but only replaced the in tank pump. which cured a world of issues. I then could drive more than a 20 mile radius from home without run-ability problems and more noticed, was that I could have less than a half a tank of gas without compounding the problem. It would always start completely cold without any hesitation, everything would change after it would get fully up to operating temp. I would stall and not restart, spit & sputter... IF I let it sit for 1/2hr to hour it would start again and then I could drive home. Sound familiar? The symptoms mimic the TFI ignition module problem pretty closely .
you may already know this, but I had very good luck replacing the in-tank pump by taking the box off.
Now this may not be the issue with yours...but you do need to check it
