FX4 manual xcase
86isuzu
TRS Member Since 2003
Firefighter
EMT / Paramedic
ASE Certified Tech
Ham Radio Operator
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Hey all,
I've an '03 FX4 level II with the manual tranny & transfer case. It does not easily shift into a gear other than 2H or N. 4H kinda goes in, and seems to work, but finding the notch (assuming there's a proper notch) is vague. I have yet to get 4L to engage. Also, the 4x4 dash lights do not turn on, either at start up or when attempting to engage.
I do have a B2 with the manual transfer case as well, so I know what it should probably feel like.
Any tips/suggestions?
fastpakr
2,842
Roanoke, VA
Have you tried adjusting the linkage on it?
86isuzu
Firefighter
EMT / Paramedic
ASE Certified Tech
Ham Radio Operator
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Not yet. I honestly wasn't sure where to begin. I'll crawl underneath and check it out. I assume its similar to the older BW1350?
fastpakr
2,842
Roanoke, VA
I believe so. I've never had a manual shift 1354 so I'm not absolutely sure.
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
Adjusting is a bit fussy. I don't know about the older BW1350, so I don't know if they are the same. I tried using the adjusting method described in Ford Service manual and it did not work for me. I came up with a different approach but don't remember the details.
My transfer case was replace early in the warranty period. The dealer tried three time to get the linkage adjusted right and could not. I told them I would just do it myself.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Yes, they’re basically the same t-case and are adjusted the same.
85_Ranger4x4
17,953
SW Iowa
Mine got funky but it was because the linkage came loose on the trans.
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
If the small bolt that screws into the extension housing gets loose, it will definitely let the linkage get out of adjustment. That is what is used to adjust the linkage. I think it is referred to as the cam plate locking bolt.
If the big bolt comes loose, it could allow side play in the cam plate and make the linkage feel kind of weird.
85_Ranger4x4
17,953
SW Iowa
I think it was the small one but it has been many moons.
86isuzu
Firefighter
EMT / Paramedic
ASE Certified Tech
Ham Radio Operator
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Awesome. Thanks. I will check that out.
North Idaho 5.oh
551
Idaho
Ford ranger
Stupid question, how does the bushing look on the shifter lever?
