Gen II Bronco Drivers side rear panel removal?
Thighman
California
I have removed all the screws from the panel but it still doesnt want to come. It seems as though the fabric trim piece up near the window is what is keeping it in place, how do I remove it or loosen it
Thanks
Thighman
California
Already did that. The panel I am refferring to is the huge piece that includes the wheel well cut out
Tony Raine
17
Jonesboro, AR
302
are you sure you got all the screws?
theres some under the carpet
its all one piece, all the way to the roof, so the seatbelt has to come off
if you have the side storage compartments, i think you may have to take them off, or the screws are accessible from inside
oh yeah, looking at some old pics of mine, theres some clips holding it too. best pic i have is the pass side
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
That trim piece below the window is held with those plastic pin things that just push on. Pull it off and there should be a few more screws behind there.
Thighman
California
Basically I am trying to gain access to the rear portion behind the wheel well. I am hoping that there is enough room to mount an air compressor and then cut a piece in the plastic just for the sake of ventilation.
I have found the screws below the carpet and now im just struggling with the trim piece. BTW junkie is that the fabric tric piece. And if so do I pull up or out
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Pull out (maybe wiggle it while pulling).
It has those plastic finned pin thing-a-ma-bobs behind it that hold it in the holes. They should just pull out (although on occasion they do sometimes break off)
BlackBII
Ranger Custom
Truck of Month
984
UT
It has those plastic finned pin thing-a-ma-bobs behind it that hold it in the holes. They should just pull out (although on occasion they ALWAYS break off)
Fixed it for you. :D
