Going a size up
miller time
rockfalls IL
FORD
3.0 duals out the back 4.0
Ok if I get 33-12.5 will they rub the frame when I turn
I got a 3in body lift
Thanks for the help
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
what do you have now??? 32x??? how much backspacing on your wheels? cant just ask if it will rub or not if we dont know what you already have.
Surrey
10
Vancouver, Canada
2.9
Also need to know rim size/backspacing.
Although I would think 33s would rub all over the place with just a body lift.
miller time
rockfalls IL
FORD
I got 15-10 rims they are America racing rims I don't know the back spacing
Yes I have 32s now
straycat
77
02 06 and 2012
Jeeps
32x? 10.5, 11.5, 12.5??? You do not give enough info. You really should use the search function. 10 inch rims will most likely rub something on the suspension without a proper lift. A bl does not always solve an issue with taller tires. Can't help you if you don't know the backspacing of the rims. Incorrect backspacing can cause issues with taller/wider tires.
miller time
rockfalls IL
FORD
