Gt-12
JoshT
1,789
Macon/Fort Valley, GA
Gwaii quick question that's a little off topic. On your tarp shop, how do you attach the tarps/plastic to the frame? Do you stretch it tight and secure on the edges, or secure it to each stud? What did you attach with?
I've got one of the Harbor Freight shed in a box deals that the cover finally came apart on. The frame is still good and should be sturdy once a few screws are added to tie the poles together better. I can't see throwing it away. Picked up a large tarp to stretch over it to use as a "temporary" carport to park my lawnmowers and motorcycle under out of the weather. Just not sure about the best way to attach the tarp.
A shop will be coming this year, but got to clear off a little property before that can happen. Fortunately show isn't an issue here, just wind and rain, so a temporary shelter should suffice.
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I used 6 mil poly on my 2 x4 framed shelter. I uses lathe and screws after stapling the poly tight.
sent while sitting on the throne
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It lasted two years and wasn't bad when i took it down.
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
It's just stretched tight and stapled at the edges for the top,edges and studs for the walls.I covered the walls first,then lapped the top over the top edges of the walls a bit then folded the edge under to form a drip edge.
Where I am wind is the biggest concern,so making sure there was nothing for the wind to catch was imperative.This meant lapping seams and getting the staples close together and within 3/4'' of the edge of the sheet.
Tarps have a bit more strength,but catch the wind so I used the tarp as support then overlaid with 6mil poly.It's smooth enough that the wind won't catch it and while snow is not usually a big issue here,what we did get would slide off easily.Just make sure it's pulled drum-tight,this will also give strength to the structural frame as a stressed skin.
The poly is available in a 20x100' roll so roof seams can be eliminated on most sheds that would be build in this method.Also,lining the inside with tarp or poly will help with strength and reduce condensation buildup.
Mine lasted about 8 years,I just took it down this past winter to make room for landscaping changes to the property.Now that I own the place a more permanent structure will be built once the house is closer to completion.
Hope this helps:icon_cheers:
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
gwaii
2010 OTOTY Winner
66
haida gwaii
460
hopefully we can get one with paint on it one day.....
Oh yeah,I bought a dodge a while back.I'll post a pick of it later.
MountainMike
84
Canada
245 CID
2"
31"
A dodge, eh? Alright I'll give you the benefit of the doubt.
Sent from Villa Auditore using a carrier pigeon.
gwaii
2010 OTOTY Winner
66
haida gwaii
460
sorry,been out of town a few days.
That's it.Looks a bit rough but it drives ok,and it's kinda fun.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
lot o kewlz thar.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i suspect...my truck is slowly turning into one of those:icon_surprised:
gwaii
2010 OTOTY Winner
66
haida gwaii
460
Hey Bobby...long time,etc.
The old girl's seen better days but it's all original.Flathead six under the hood,military tags on the dash,24v electrical system and such.She don't go fast,but she starts every time....though I had to play with it a bit to get some rumbles from the pipes.
It's a '51 M37,and while I figure I'll take care of some structural issues I kinda like the weathered look so I don't see any fancy paintwork going on any time soon.
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
I'm sure someone has already told you this, from the movie "Cars."
gwaii
2010 OTOTY Winner
66
haida gwaii
460
Twins separated at birth,perhaps?
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
yay i made gwaii come back to trs!!
gwaii
2010 OTOTY Winner
66
haida gwaii
460
I never actually went away.....there was just a little more time between posts.
