Hagan's '86 Ranger build!
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
Figured out my cutting out issues. Fuel pump wasn't strong enough and couldn't flow enough fuel. I upgraded to a vane style fuel pump frim Airtex.
New vs old
Mounted basically on the tank
85_Ranger4x4
17,933
SW Iowa
300I6Ranger4x4
Chilliwack, BC
351w
We must do the things we think we cannot
I finished my Painless adjustable fan controller install. It was super easy and so far works great.
what e-fan are you using? could i use that painless temp sensor with my taurus fan i just got from the jy?
300I6Ranger4x4
Chilliwack, BC
351w
or is there a cheaper jy route i could take once again?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Get you a bmw dual temp sensor and a volvo relay. Gets rid of the "temp sensor probe in the radiator" route...
SVT
85_Ranger4x4
17,933
SW Iowa
I have a "painless" efan kit that had a probe that was 3/8" pipe I think that went into my intake. It runs a relay that runs my fan. The kit wasn't terribly cheap and the relay was a generic relay. Easy to make if you find the switch.
Hagan
11
Salem, OR
2.3
Should of just went mechanical and been done with it :icon_twisted:
Your Holly pump looks like a twin to my Mr Gasket. Wonder if one is a restickered version of the other.
http://www.summitracing.com/parts/mrg-12s
LOL mechanical is the only way to go!:icon_rofl:
The pumps do look identical. I bet they are the same manufacturer.
I'm using a pusher fan off a v8 or v10 Mercedes or Jag. I can't remember which. I roamed around the junkyard for an hour looking at fans and found one I liked and felt like it pushed the most air.
Yeah you could use the Painless adjustable fan relay with the Ford Tortoise fans. My brother is using a set of Volvo fans (Same as Taurus I believe) and fan relays that have a low and high setting.
No updates on the Ranger. Although my electric choke stopped working and found out a screw in the carb backed out causing it to not close. Also, I've begun construction on a 12'x16' shed so I can move everything from my garage to my shed and begin my Cummins swap on my '89 F350
Hagan
11
Salem, OR
2.3
Got a little bit of work done on the Ranger. Changed the oil and made a mount for my Bussman fuse box. Got tired of seeing it flopping around under my hood. Took my Ranger out in the snow a couple times but didn't take many pics.
I've also decided to upgrade my pusher fan on my 4.0 radiator. I went with a Flex-a-lite FLX-398 16" Syclone fan. We'll see how it works out. I think it's a little bigger than my fan I'm using. I'll be using it as as pusher so hopefully it's still adequate.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,796
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I'd love to see some updated pics of this truck.
Hagan
11
Salem, OR
2.3
Sadly I don't take many pics of my truck anymore. But it's pretty much the same as its been for the last year.
Here is the most recent about a month ago.
Towing it with my beater. Didn't have a front driveshaft on my F350 yet.
Here is my fuse box I made.
Hagan
11
Salem, OR
2.3
New rubber! 37x12.5-r15 Irok radials on bead locks
chris1972
ASE Certified Tech
murray ky
nice truck whats the tire size
Hagan
11
Salem, OR
2.3
Jim Oaks
Administrator
Supporting Vendor
8,796
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
