Hard front end lean
Dhunter839
2003 2wd 3.0 with 220k on it. My front suspension leans hard to the front left, I believe the tire even hits the fender on hard enough bumps. Are the factory coil spring known to break, I really need to get this fixed because it is wearing into wheel bearings pretty hard. Thanks!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Did you jack it up and have a look?
That's where I would start...
Dhunter839
yes, nothing easily visible seen broken. Measuring LF fender and RF fender ground to wheel opening I have like 29 3/4 on passenger side and 28 1/2 driver side. I can see where the tire has marks from rubbing the fender, also marks inside fender liner.
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They could just be worn out... but it sounds like something is broken.
Did a coil bucket break from the frame?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Rear springs ok? Tires same size?
Dhunter839
Rear end is fine already replaced shackles and hangars a while ago. New upper control arms within last year and lower joints also.
Bgunner
1,097
Western Mass.
Ford/Ranger XLT
225/70/R15
Coils are known for weakening and loosing height over time. It is possible this is happening to you if buckets check out good.
I've lost over an inch in the front height due to the springs softening over the years.
Dhunter839
Recommendations on replacement parts?
ericbphoto
Overlander in development
16,735
Wellford, SC
6"
Have you checked body mounts? Suspension might be fine, but body drooping.
