Hard starting, smells like gas
GingerKid
Beecher, IL
Over the last week or so, it seemed like my truck was taking longer longer to start. It got to the point last night that I could crank it for a good 5-7 seconds, give up, try again, and it would start right up. This seems to happen mostly when the truck is cold. Also, when getting in the truck it smells strongly of gas. I don't notice it as much outside, or even in the cab, only when I'm getting in the truck. I also have a cold, though, so I have some trouble smelling anything.
This may be unrelated, but how high should the idle go on a cold start? My truck goes to 2k for a little bit then slowly settles down to around 1100-1300. It also seems to idle a little high sitting at a stop light, but still only at about 1100.
Any ideas on what could be causing this?
BlackBII
Ranger Custom
Truck of Month
984
UT
Given that it's idling a little high, I would start by cleaning out the IAC, make sure the plunger can move freely.
Big Jim M
30
Austin
Long, hard, cold starts are a sign of "leaking back" which is the fuel leaking back into the fuel tank over a few hours.. Try this: First thing when the engine is cold turn the key to the run position to allow the fuel pump to charge the system..for 5 or 10 secnds.. then turn the key to the start position and see if that helped. If it did you now know why it is hard to srart in the mornings.
Big Jim
GingerKid
Beecher, IL
Alright, I'll give that a try. If not, I'll clean the IAC. Actually, I should probably do that either way. I'll update hopefully tomorrow.
GingerKid
Beecher, IL
I let the fuel pump prime for close to ten seconds, and it still took a while to start. It seemed like it was a little shorter, but not by much. Also, I noticed my coolant temp guage fluctuating a decent amount. It was moving was faster than the coolant temp could actually change though. Could this just be loose connection or is it also possibly related.
The gas smell seems to be getting stronger too, I noticed it sitting in traffic with the window open.
GingerKid
Beecher, IL
As of yesterday, I started noticing a big puddle right under the driver's door. Didn't see it before because I was parked on gravel, so it blended in better. Fuel filter is rusted to hell and leaking. Replacing it today.
BlackBII
Ranger Custom
Truck of Month
984
UT
Good luck! I've had a few leak as well.
Let us know if that fixes your gas-smell issue, I bet it will. Also, you'll probably notice better fuel mileage. :icon_twisted:
GingerKid
Beecher, IL
Yup, not smelling it anymore. I figured I was just smelling the puddle right underneath my door when I was sitting at stop lights. No more leaks, haven't checked mileage yet.
