Heat shrink tubing
Dangeranger3
Peoria, IL
420
Has anyone here ever used heat shrink tubing to repair a vacuum line? My PCV line is busted and its a crappy plastic piece that I think I will have to get the whole thing from the dealer :pissedoff:
almostclueless
Unless space is a concern, cutting the plastic line and using an ordinary vacuum hose between the ends should work fine. Ford was just being cheap so they could continue paying their execs too much money IMO.
Dangeranger3
Peoria, IL
420
Actually this is on the devil chevy lumina I been workin on. I called the dealer and its $108 for 3 little pieces of plastic. The plastic hose connects to a plastic T and broke off inside it. So I'm gonna try the heat shrink method to patch up this piece.
Dangeranger3
Peoria, IL
420
The heat shrink worked like a charm after goin to 2 dif stores to get it. Even though one end was on 1/2 in and the othe end on 3/8 it sealed up just fine. Now as long as it holds...
jetcjcski
July STOTM Winner
MTOTM Winner
Mazda
sounds like a good idea to me, i probably wouldnt have thought of it
MAKG
19
California central coast
Yeah, I'd be concerned about longevity. Heat shrink assumes there is a nice stiff wire inside holding it together....
There is nothing wrong with replacing the hard line completely with flexible vacuum line (in bulk), or with making patches out of that (BTDT).
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The heavier type of heat shrink with the hot melt glue inside it works great for sealing the little plastic "spagetti" lines....
Polyolefin plastic is neat stuff...
AD
